PCMark 8 Video Editing
Video Editing Part 2 V2 (Creative 3.0 test suite)
This workload uses
FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom-built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
Intel Core i5-7600K (5.1GHz)
Intel Core i7-7700K (5GHz)
Overclockers UK Titan Osprey
Intel Core i7-6700K (4.8GHz)
Intel Core i5-6600K (4.8GHz)
The PC Customiser Venom VR Powered by Gigabyte
DinoPC C3 Mod Gaming PC
Intel Core i7-7700K
Intel Core i5-7600K
Intel Core i7-6700K
Intel Core i7-6850K (4.4GHz)
Intel Core i5-6600K
Intel Core i7-6850K
PC Specialist Magma Zen
Seconds (lower is better)
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using
ImageMagik - an open-source image processing library - to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
Intel Core i7-7700K
Intel Core i7-6850K
Intel Core i7-6700K
Intel Core i5-7600K
Intel Core i5-6600K
